rebuild ?
Started by 78man, January 12, 2012, 02:13:36 PM
78man
When do you need to rebuild an engine. The miles on my truck are sitting over 159,###.
Jakes Brush Removal
when it don't go no more,  i got   235,  on  mine  your  good to go for a wile
Buck
chevv chevgal chevvv
Cylinder compression test will tell you..
not knowing your motor.. averages would be...
difference between cylinders should be no more than 5 - 10 psi..
and be no more than 25% under factory recommendations.
78man
Jakes Brush Removal
if its not smokin or knockin then just keep doin scheduled maintenance  untill it does
Quote from: xjs3667 on January 12, 2012, 04:46:24 PM
Quote from: Blazin40s on January 12, 2012, 03:40:24 PM
Till it goes BOOM!
