can someone help me decode this 350?
Started by jwang203, January 14, 2012, 04:48:07 AM
jwang203
Here is a picture of the stamp above the water pump. I cannot find out what this came out of other than its a 350. Any help? Thanks.
the rest of the casting numbers can be more of a help than those ones....their easily faked or changed...
the ones on the bell housing flange and the ones on the heads are more important
Im not coming up with anything either I think its a fake stamp,  get one off bell housing flange and I can run that one   ;D
jaredw
ok thanks I will try and get one tomorrow
==dew
Its a 1988 350 E.F.I V8, R/V models truck engine, RPO L05.
http://www.camaros.net/forums/showthread.php?t=23337
jaredw
Thanks. I wasn't able to get another picture of it.
==dew
V0627PHD
V- Flint Engine
06- June
27- day 27th
PHD- 1988 truck 350  195 hp TBI
Im pretty sure second stamp is fake as when I run it i keep coming up with 68-69 camaro 396, but I will keep checking, but the only way to know for sure is to get the number trans flange  ;D
ok and after some real long hard research for ya this is what I found on the partial vin
CJF189958
C-Chevrolet
JF- HD truck 3/4 or bigger or RV
1-Chevy
8-1988
9- Detroit Assembly plant or Oshawa Assembly plant
jaredw
Thanks guys. This motor was purchased as a rebuild from someone. After installing it and having tons of issues it spun a crank bearing after about 300 miles. Its coming back out.
==dew
perfect time to do some upgrades to the motor then man!!!!
jaredw
its in a friends DD truck, stock tbi setup 1994 k2500
==dew
I would also get the one that is cast in the block by the bell housing.
I know the one on the front is the plant code but the other will help you out as well.
mudbrat71
got a 94 350 tbi $300 run good when i pulled in dec
