91 Wrangler
Started by Air Force Fireman, January 21, 2012, 12:15:53 PM
Air Force Fireman
I have a 91 Wrangler that is going to have a 4.0 and a 5 speed in it. Right now I have 2 different axles (rear was gone when I bought it). So they are geared differently. I also have the axles (geared the same) out of my 1971 GMC 1/2 ton pickup. I was thinking of putting those axles under the Jeep. Just wondering who has put gmc axles under one before, how difficult it is, and if it's worth it. Thank you.  a=f
God Bless America!  a=f a=f
dogred
i have one right now that i am doing.  just use your imagination and a welder, i am also doing engine , transmission , and transfer case swap.....
HE WHO DIES WITH THE MOST TOYS WINS ----- tresspassers shot  violaters violated  survivers shot again ------ GO HARD OR GO HOME----
Air Force Fireman
Thought about doing the engine, tranny and t-case, but I already have it all from my other Jeep, so I'm gonna just stick with that for now. Cheaper that way. a=f
Squirell
if you dont mind the front axle sticking off to the right a inch it is easy. if you do mind it takes a little fabricating...I just did it to mine. you just have to grind perches off and put new ones (or reuse the old ones) on. it took me three hours to switch axles and weld new motor mounts in. but my axle stick to left a inch.....i used ford axles
Just torch off the old spring mounts and weld in some new ones in the right location.  Pretty easy.
Air Force Fireman
Thanks guys. Figured that's about all it'd take. I'm gonna make sure the axles are all good to go and gears are all good first, then I'll get to work on that. a=f
Squirell
Quote from: four_by_ken on January 23, 2012, 01:28:17 PM
doin it this way(which is how i did mine) the axle sticks one way or the other( depending on the drop on the axle) a inch
dogred
have a front axlefrom 88 wrangler that totally rebuilt and new gears ---4.56--- complete with brakes ----500 dollars
camok10
#8
those are 73-87 gm axles with the only lift being a spring over axle the spring pad width is allready the same as a yj 31.5" and it gained roughly6" of lift the jeep also had a sbc motor 700r4 trans and a dodge np208 case with a gm input shaft because the dodge cases dont have the rear slip yoke and have a pass side drop
84 c10 project
82 c10 beater diesel
Air Force Fireman
I like the look of that Jeep with the wide axles on it. I think I'll do this with mine as well. I just have to get back and start working on it! a=f
camok10
heres a back side shot the fender flare on the rear was at the middle of claw and they were 35x13.50's just for an idea on howmuch wider it will be it think the wheels were a 15x10 with 3.5" back space if i rember right
84 c10 project
