roll cage tube size ??
Started by BigFrank, January 22, 2012, 10:35:56 PM
debating what size to use as well as wall thickness   whats thick enuff per pipe size  and what are any advantage/disadvantages    the truck cab is small and i  want it inside the cab  ==wgm
1.75 is most common size .120 wall
Wild One
Comp Bog,  check the rules.
Play bog, how safe you want to be?????
MidMichiganMudRun
In my new comp truck I am using 1 5/8 x .134 Mild steel
Wild One
CRC rule:
ROLL BARS & ROLL CAGES-ALL ROLL BARS & CAGES BUILT AFTER 2006 MUST BE 1-5/8 OR MORE BY .120
WALL STEEL OR 1-5/8 CHROMEMOLY X 0.090 WALL, (NO SQUARE TUBING OR THREADED PIPE) MOUNTED
WITH 3/8 GRADE 5 BOLTS TO FRAME.
C.R
'the DON'
thats what im running 1.75x.120 dom
Quote from: Crazymays77 on January 22, 2012, 10:37:42 PM
==wgm
thanks for the info  the 1. 75 x1.20 should be heavy enuff     i want it to be safe for shure  there aint much metal on this old cab
MidMichiganMudRun
.134 is heavy duty but better safe then sorry.... I crushed my 1.50 X .090 wall so I went big this time
wher you getting your material at ??  i know theres lots of places  but drivin hours ads up  to offset the savings   im also thinkin the main hoop behind the seat and the legs down to the front will be the thicker wall pipe
MidMichiganMudRun
There is a company out of flordia that will custome bend all your pipe for you and ship you a 8 point cage for under $450... its called applied racing... I found them on racing junk.com
Quote from: puddlejumper on January 25, 2012, 03:37:21 PM
awesome  im gonna check it out  thanks
4-play
I got a 12 point for that price from S&W...a lot closer
