leaking freeze plug after i replaced it
Started by Crazymays77, February 04, 2012, 06:11:17 PM
ok i replaced the freeze plug and its still leaking around it. what did i do wrong?
did you put some sealer on it when you put it in.
they make  rubber  soft plugs to. maby try one of them.
there  realy no way to know what you did wrong  i was not there when you did it.   maby  you did  nothing wrong. it mite be one of them that just going to give you a bunch of p00.
Idk it's a very small leak just a little wet at the lip.
well i found 3 more leaking. damn it should have looked closer i guess. 2 on driver side 2 on pass side. fixed one on pass side now i have to take the manifold off so i can get to the other one leaking just had to be the very back one. the driver side is the front too. think i can replace them without pulling the motor.
