91 cherokee tilt steering
Started by xjs3667, February 08, 2012, 07:30:24 PM
the tilt steering on my 91 xj basically took a dump lol it still works but where ever I lock it in at it has like 2-3'' of play,
ive never torn into a column before other than doing ignition cylinder and just swapping columns, so if anyone has had similar problem how did you fix this other replace whole column?
thanks all
paul
if u can bring it to me i can fix it in bout 5 mins its kinda hard to explain what to do over the puter. ive ran into this prob with a few dif people
respect the buickk
paul
i just googeled it and theres to dif things it can be one is the pivot pin or 4 screws way deep inside the colum heres sumthing that will prolly help ya
http://www.bc4x4.com/tech/2009/jeep-steering/
respect the buickk
Quote from: paul on February 13, 2012, 06:12:33 AM
thanks bud, that was a great write up.  I think im guna give a crack at it :)
paul
have fun and let me know how it turns out for ya
respect the buickk
got it done, took about an hour and needed no special tools other than steering wheel puller, hardest part was lining up pin and rod for the highbeam headlight switch but other than that its a lot easier than I thought. thanks for the link :)
paul
no prob what was it the bolts or the pivot pins ???
respect the buickk
paul
respect the buickk
