need help with cherry picker!!!!
Started by xjs3667, February 12, 2012, 04:33:08 PM
yesterday I was putting in my engine and the cherry picker took a dump on me, engine is off now and cockeyed on engine mounts,    but all the picker will do when you pump it will go up one pump and back down to where it was, and it will not go down either.
any help would be usefull thanks guys.
Lowering valve not closed all the way, low on fluid, or seals are blown, try topping off the fluid with some ATF or power steering fluid
dirtydog
54.99 habor freight 8tn ram for the cheery picker got 1 two weeks ago
#3
Unfortunatly I dont have 60 bucks to buy a new ram, I got the picker from hf, and there is no leaks that I know of, what I need to know is how to fix the one I got,    also put more fliud in and still nothing the hadle will pump one pum then it drops down to where it was and haddle pops up where it wss.    Is there a check valve in these that might be stuck open?
dirtydog
Quote from: xjs3667 on February 12, 2012, 05:06:39 PM
if u need to borrow 1 i got mine though u gotta come get it and return it when your done within a week i gonna need it back
Its got simple o-rings in it. Take the ram off and take the valve apart, put new o-rings in fill it up n it should work. Bleed it by extending all the way and pushin ram back in by hand with ram standin straight up. Might have to take the ram out of the cylinder as theres some more in there on the piston itself, most likely.
Quote from: dirtydog on February 12, 2012, 05:15:25 PM
I might have to take ya up on that offer...... im going to try and take it apart first and go from there,  lol everything was going so smooth with this swap to lol I should of figured somthing stupid like this would happen lol
dirtydog
