WARN M8000 problem
Started by Jthomas, February 13, 2012, 09:34:23 PM
So I got this ^^^ winch. I have never had a winch befor :( and I can't seem to get it to work. I do not have the remote for it, but I can't get it to release the cable, or anything. Do I NEED the winch for this thing to even work?
I checked it with the light, and it is getting power.
I just can't get it to operate at all.
Yes I may be a  ==noob with this thing, but I'm just asking.
I called WARN and they didn't really have much to say.
Quote from: Jthomas on February 13, 2012, 09:34:23 PM
i do believe you need the winch to do anythingyoull prolly need the remote to control the motor
Quote from: OHEARN.2012 on February 13, 2012, 11:03:07 PM
Lol ahahah sorry. I meant the remote, not winch.
Quote from: Jthomas on February 13, 2012, 11:16:29 PM
Yea just get a remote
If you switch it to neutral, shouldn't i still be able to pull the cable out. (I need to replace the cable)
Can you rock the drum while switching it to free?
Quote from: TopFist on February 14, 2012, 12:40:37 AM
I don't remember, but I don't think it did. It was last summer when I got it, then I just said to hell with it.
Goldeneagle
i have a 3500# winch and in order to get it to run off the truck i need a extra ground from the battery to a common ground on the winch plate as well as pos. and neg. cables hooked up.
ron
so its not barbies jeep maybe its daisey dukes.
So run a ground from the batt to an external part of the winch? And I tested the remote socket, and it is powered.
