Methanol Injection??
Started by OHEARN.2012, February 19, 2012, 03:43:04 AM
Quote from: erikmud on February 21, 2012, 05:52:56 AM
Do you have a build thread on your jeep it sounds pretty bad ass, and I could probably tell if something goes wrong with the injection while running by the sound of the motor but I would rather be safe then sorry, already been through a couple motors don't want to risk another one
Nope I dont have a thread of the build, I built it before I was member, but im guna be doing some right up's of stuff that im that im guna be adding on or modifying soon now that I got tax money lol
Quote from: xjs3667 on February 21, 2012, 04:47:52 AM
Quote from: erikmud on February 21, 2012, 04:18:05 AM
Yeah but the kit we are getting has the electrical stuff so it can be tuned to come on at a certain rpm and shut off the motor if it senses any problems, with a high compression engine the low octane pump gas will detonate the motor if the injection system were to fail it would be pumping just 93 into the motor so the electical stuff has a saftey feature that a self built kit doesnt
I hear ya im runnin 14:1 cr  yet I got a blower on there too, so only need the meth when the boost is going since as soon as I let go of throttle bypass valve opens and im back down to around 8.5:1 cr.   so Im guna have it set up so it sprays when I have boost and if it does fail I will obviously know right away from the knock and its just a matter of letting off the throttle for me  lol  but every set up is different, so good Luck with it  :)
With alky you don't detonate. Run all the boost and compression you want.
