hydraulic assist
Started by Kyle, February 21, 2012, 09:18:09 PM
Kyle
anyone set one up on an 88-98 gen chevy truck? psc dont seem to have anything anywheres or even a kit... lookin to set one up for my truck. are there steering boxes that are pretapped for a ram? can i still use my oem pump for it? what size ram do i need?
xjs3667
just wondering why you would want hydro assist?  if your guna do all the work to put a ram in etc.etc. then why not full hydro steering?  and yes stock pump will work and someone else is guna have to tell ya about ram size and all the specifics,   do a search in the search box this has been covered before :)
Kyle
cuz this is goin on my dd, otherwise i would deff go full
Kyle
#3
http://www.pirate4x4.com/tech/billavista/HydroAssistTap/index.html
got most of the info
now just need to figure out what ram to use and how long the lines need to be....
is there any real plus to running a psc vs a regular ram? will a regular ram move fast enough for a normal steering system?
http://www.northerntool.com/shop/tools/product_21342_21342
vs
http://www.pscmotorsports.com/motorsport-specific-products/offroad/cylinder-assist-gears-kits-components/assist-cylinders/2-x-8-assist-cylinder.html
xjs3667
I've only dun fully hydro setups so got no clue lol but I see why you ask cuz of the price difference, But I would imagine since they are both 2in bore 8in stroke that they would use the same amount of fluid/ pressure to move it, as for it being able to keep up with gear box  and after reviewing the links you posted It looks like they are using the gear box kinda like the orbital valve on a full hydro, only allowing as much fluid to flow as you turn the wheel,
wats the benefits of hydro assist?
Kyle
Quote from: OHEARN.2012 on February 22, 2012, 05:19:19 AM
Steering is less likely to bind up when caught between a rock and a hard place and its less stress on the power steering box havin to push around the bigger tires and extra steering stabilizers
hmm maybe an added upgrade when i sas ???
