What are you running for hydraulic steering and what is recommended?
Started by 989F150904, February 23, 2012, 02:28:56 PM
989F150904
Hey guys, in a few days I'll be to the point in my project where I'm going to need a steering set up. Wondering what is the easiest way to run hydraulic steering and not brake the bank? Do I just find someone parting out a tractor and fab it up to my set up or does someone have a system for sale like that? Can ya help me?
Go find a tractor junk yard get the orbital valve, hydraulic ram, and hydraulic lines, I got all that stuff for 50 at a local place, you can buy aftermarket set up and it probably comes with brackets but I'm sure its not cheap
since your in vasser area id say go to caro at riverveiw junkyard  hes got all kinds of junk equipment  there were a bunch of forklifts last time i was there could get the valve  and lines id buy a tsc ram so ya know thats good  dan at quality auto in caro can make up the lines for ya and thats easier than trying to use lines from yard or tsc
989F150904
Quote from: erikmud on February 23, 2012, 02:39:09 PM
Quote from: BigFrank on February 23, 2012, 02:54:13 PM
Cool. It's pretty easy to install and set up then? Also, these would be belt driven or electric pumps?
You can use your factory power steering pump you have to lines that run from the pump to the orbital then from the orbital down to the hydraulic ram but the after market kits come with a pump and I believe those are belt driven
989F150904
Quote from: erikmud on February 23, 2012, 03:19:34 PM
Sweet. Thanks!
71 Highboy
Lamrocks in Otisville always has valves for sale, hoses and fitting will be the biggest cost, mount your valve as close to your pump so you can run shorter hoses. Might need an extra resivior for ps fluid.
TNT BOGGING
Shouldn't need a resevoir with the tractor parts but maybe the aftermarket set up
989F150904
Quote from: 71 Highboy on February 23, 2012, 04:24:57 PM
Quote from: erikmud on February 23, 2012, 04:31:11 PM
Ok
I can give u a hand getting it setup when ur ready. I can even plasma out the brackets if need be.
Also my father in law works at riverview. I can have him see if they have any and maybe he can get it cheap for ya
989F150904
Quote from: Crazymays77 on February 23, 2012, 05:03:07 PM
Quote from: Crazymays77 on February 23, 2012, 05:04:29 PM
That would be sweet. I have a plasma cutter. Ya, ask him what he can find and hook me up. I appreciate it.
Now that I think about it Im going to caro after work I'll stop in and talk to him. U want just the orbital valve right? I'd get a ram from tsc and get new lines made up. What u want to spend on the valve?
989F150904
71 Highboy
the new style ford pumps, the plastic ones are pretty small the old style metal ones were bigger, may not be a issue just giving a heads up
TNT BOGGING
