14 bolt diff removal help
Started by haydenlloyd88, February 23, 2012, 08:01:28 PM
haydenlloyd88
Could someone give me a step by step on removing the diff from a 14 bolt rear?
Never done it before and don't want to mess anything up.
Pull the cover off and remove the bolts holding the retaining clips off, then screw in the cylinders with the holes next to the carrier.  Then it should pull out.  Just remember where the adjusters were at when u pulled it
Gotta pull the axle shafts first tho
haydenlloyd88
Quote from: Blazin40s on February 23, 2012, 08:10:36 PM
Do the axle shatlfta gotta come all the way out? What do I do with the drum brakes?
haydenlloyd88
Just pull the shafts out a foot or so.  And u leave the drums alone.  I assume yer talkin about a 14ff?
haydenlloyd88
Quote from: Blazin40s on February 23, 2012, 10:26:18 PM
Correct
Real easy man.  Just gotta put it back the exact same way to keep the pinion lined up with the ring gear.  Also should be an articke on www.pirate4x4.com in the 14 bolt bible
Boggen Joe
Yep easy
1 pull diff cover off
2 pull both axle shafts out a ft or more
3 pull the 2 little two prong clips
4 pull the two retaining clips
5 turn the two cams on side of carrier till carrier comes out ( count the turns )
That's bout it
haydenlloyd88
i fu%$&*% up hard when i did mine i didnt keep track of the turns should i be worried ??? ==doh
haydenlloyd88
Quote from: OHEARN.2012 on February 24, 2012, 03:12:00 AM
see this is why i asked questions cuz i woulda done something like that,
i usually mess things up when i try to feel my way through things
Quote from: haydenlloyd88 on February 24, 2012, 03:14:02 AM
well actually yes i did count them but i had the diff out for so long that i just forgot the amount of turns
haydenlloyd88
Quote from: OHEARN.2012 on February 24, 2012, 03:17:00 AM
been there, done that brother pullhairr
black07ss
The purpose of the cams is to take up the slack or "runout" between the ring and the pinion. If you have forgotten the number of turns all u need is a dial indicator (and magnetic base) and adjust so there is only about .008" of runout between  them.
If its not adjusted properly you'll mess up the gear
