wiring up choke
Started by Captn. J, February 25, 2012, 01:33:16 PM
i know i ve done this but wanna make sure   i know one wire is ground and the other one ? what or where shd i wire it to?  will be a 350 chevy
The hot wire comes from the run position on the key and goes to the round plastic thing on the side of the carb. ==np
is the round thing the wires plug into supposed to get warm? i hooked mine up, got warm, so i unplugged it...
Quote from: J.C. on February 25, 2012, 01:44:05 PM
Yes. Its a bi-metal spring inside and it gets warm and opens the choke. It stays warm the whole time motor is runnin. If you unhook it the choke closes as it cools off.
Quote from: old school truck dude on February 25, 2012, 01:47:14 PM
Yes. Its a bi-metal spring and it gets warm and opens the choke. It stays warm the whole time motor is runnin. If you unhook it the choke closes as it cools off.
nice! ill hook it back up then ++peace
Quote from: old school truck dude on February 25, 2012, 01:42:17 PM
can i just wire it to the battery? or something else? it s in a bogger
Quote from: Captn. J on February 25, 2012, 01:50:12 PM
run a toggle between battery and choke?
No. Youre choke will always be open, be real hard to start. Hook it up to the same spot that your dizzy wire hooks up to, but do not splice into the dizzy wire. If you splice into the dizzy wire you will draw juice away from the dizzy and lose a little or possibly alot of your spark. Find the terminal in your fusebox for the run position or hook it up right on the ignition switch on the terminal.
Quote from: J.C. on February 25, 2012, 01:56:03 PM
That will work, dependin on how how bad you suffer from short term memory loss at this point in your life ==roll
seems to happen alot loll just place it near the other switches so you dont forget to turn it on :)
Quote from: old school truck dude on February 25, 2012, 01:57:43 PM
i ll do that  instead the toggle  cuz i will FORGET  but the dizzy get consant power so meaning the choke will too? if i wire it to same terminal
you only get power to the dizzy when the key is in run. so yes, if you were to wire to the same terminal that should be fine.
Again, hook it to the terminal, dont splice into the wire, I been down that road before ;D
Kyle
make sure that power wire to the dizzy ur wiring it to IS NOT THE COIL if its an hei dist. after the motor is runnin the coil drops the supply down to 9 volts and the choke wont work properly then. needs to have a constant 12 volts
Quote from: Kyle on February 25, 2012, 02:13:03 PM
x100000000  The old points style was like that, the HEI runs on a constant 12 volts.  Its a resistor wire, it dont look quite like a regular wire, that was on the old points-style ;D
