208 question
Started by Jthomas, February 26, 2012, 12:40:08 PM
It came off my 700r4, I want to put it on a th400. Will it even work? Will it mount different to the frame? What do I need to do?
it might just have to get a diff adapter for it
Quote from: Crazymays77 on February 26, 2012, 01:00:57 PM
Idk too much about drive train. What addapter do I need?
it wont work wrong spline a 208 off a 700r4 will hook to a 350th but not a 400th. but one off a 465 4 speed will work on a 400th
Quote from: betterbeaters on February 26, 2012, 01:15:16 PM
Could I just get another output spline?
Or would it just be cheaper and easier to get a different T case
yeah i forgot about that lol
either get a t case off a 400 or   get a 350th   that t case will bolt on it   or     chnange output on the 400th if u know how to tear into a trans
Quote from: Captn. J on February 26, 2012, 03:13:29 PM
What Tcase came off a 400? Like a deacent one.
you can get a 208 or a 205 both are good cases. also they came with 203s but I never liked them.
Quote from: betterbeaters on February 26, 2012, 03:43:20 PM
Scrap yard be my best bet?
craigslist or mabye look on here or you can try a junk yard...   or sell the 400 th for a 350th and build it and be done?
I got a 32 spline NP208 for a 400 turbo, 100.00 and its yours, located in Midland
Quote from: 7387chevynut on February 26, 2012, 04:41:55 PM
I'm leaving for beaver island tomarrow. I'll be back in 17 days. I'll think about it, I have to get my trans first.
chevystudz7105
to bad you dont live closer.  i got a junk 208 that has the right splined part in it ot make it work with a 400.  wouldnt take much to split the case and pull the part out.
Do I have to change the tranny tail shaft? Or parts in the Tcase.
chevystudz7105
Quote from: Jthomas on February 26, 2012, 05:49:59 PM
you can change just the part in the t case.  thats what i did to my one 208 i had.   it was attached to a  sm465 trans (which is the same spline count as a 400)  and i wanted to put it on my 350 trans i put in my truck so i jsut swapped out the part in the t case.  real simple to do
cool thanks. what part?
chevystudz7105
i believe its called the input gear.  its part number 3 in this pic
timothy
thats all I do is just change the input  shaft I have a couple 350 inputs laying around but only have 2 for my 400.  very easy to do then I just reseal them with ultra grey I have have been told I have to use right stuff but ultra grey works just fine.
