cam shaft sesnor code still on???? 05 dodge ram 4.7
Started by bud, March 01, 2012, 04:37:20 AM
bud
ok i have a 05 dodge ram 4.7 4x4 77,000 miles last week my CEL came on po344 cam shaft sensor no big deal right? wrong changed the part out cleared the code then 2 days later started the truck to let it warm up went out there to leave and the dam CEL is back on same code i have cleared the code 4 times now it will stay off for a while it only seems to come back on at start up or when i let it warm up and stays on till i clear it again so i am stuck any ideals????
bud
High Strung
I had the same problem in my 04. might kept tell me it was cam then it went to crank. then after i replaced both them it started stalling.. this all happened. in a years time.. finally after it stalled and didn't want to start up. i said f++k this. sold the truck to a dealership. that's all i can tell u. 1 mechanical said the only thing he can say is tear the motor done and start testing sensers. and check cam and crank.
Carl
2004 dodge 1500 crew hemi 3" lift
95 Stingray 454
2003 Chevy 2500 HD
92   s-10  on 38 tsl's with a 355
Excuse me do u have any grey-pu-pon
bud
Quote from: High Strung on March 01, 2012, 11:10:54 PM
yep that aint going to happen lol
01vortecpwr
bud
Quote from: Eroq on March 04, 2012, 06:42:07 PM
Does it run rough when the light kicks on?
not like its a bad cam sensor might run a little rough but not bad at all
jbeery78
 4.7s are tricky for sure.... ill bet a failing crank sensor is causing the cam code... i had a 4.7 with a smilar prob kick my butt for a whole day. Cam and crank share a 5 volt and a ground and the pcm gets "confused" haha.
Keep us posted!  ++peace
bud
Quote from: jbeery78 on March 05, 2012, 01:59:39 AM
will do i have been hearing alot about changing the crank sensor
