comp bog
Started by Blazin40s, March 01, 2012, 12:14:57 PM
I've never been to a comp bog b4.  Not even to spectaite.  So I was thinkin I may try one or 2 this year.  My question is, For those of u that are fimiliar with my rig, how would it do?  Would it be a big waste of time, or would I stand a chance?   ==noob  ++peace
you got drive shaft loops    neural safety switch        you will need to have a helmet and fire exteish with you also.
imo you would not keep up, lots of 1000 hp trucks there..... fun to watch.
MidMichiganMudRun
You never know how you will do till you show up and run it, each place is different.... and alot depends on who else shows up to run there truck
Didn't figure id stand a chance against a 1000hp truck.  Isn't there different classes to help even it up?
MidMichiganMudRun
classes go buy tires size more then anything...
O.  Forget that then, id be smoked
MidMichiganMudRun
what size tires do you have... what motor
39.5s and 355 pushin about 400hp
dogred
many different places have different rules.. some run stock classes,, superstock classes.. tire size classes,, cut tire classes.. open classes,, you just need to check them out.. some times a stock jeep with basic oversize tires might run farther than a built 502 with 44 inch boggers,,
HE WHO DIES WITH THE MOST TOYS WINS ----- tresspassers shot  violaters violated  survivers shot again ------ GO HARD OR GO HOME----
71 Highboy
You will never know until you try it, not so much about keepin up as it having fun with something you built. Our truck wasnt finished until the night before millingtons bog last year and it made it through the pit and its along way from 1000 hp,but it is a  forddd ==rocks
TNT BOGGING
you need to look at the rules at the bog you pick. you have muffers on it? you can run stock class and super stock class.
Yes have mufflers, full cage, fuel cell,
MidMichiganMudRun
No matter what if you win or lose come in 3rd or 15th its all about the fun of the sport
Think ill stick with the play bogs
71 Highboy
Quote from: puddlejumper on March 02, 2012, 12:38:56 PM
x2
TNT BOGGING
A lot of places that have a stock class want u to pull vaccuum
I would give it a shot.  Find one that isn't too far away and has a class that you fit it.
Also find out if it is a bog or more of a race.
They are fun... you might get hooked.
id do it just for fun plus youll have a sweet video of running with the beasts
have done 1 or 2 myself.. with a street rig..
wasn't too keen on the $$ for 1 or 2 passes...
but the show the big boys put on made up for it..
is generally a good time..
