project ranger SAS
Started by rangerwheelinmike, March 04, 2012, 06:22:32 AM
danwheeler660
.1996 bronco 351 32.11.50 15
rangerwheelinmike
Quote from: Kyle on March 23, 2012, 05:26:54 PM
you should modify ur radius arms and make em long arms
I will at some point cost to much right now
rangerwheelinmike
got everything cut off the axle today stared mounting the coil buckets
rangerwheelinmike
well i picked up a steering box for it today and got the frame plated where it needs to go and got the axle panted
rangerwheelinmike
welded the front diff today so now i have true 4wd lol hope to get the steering box mounted in the next cupple days trying to be done for bondy bog on the 7th but i dont know still have a lot of work to do
mariozoldos
Boggen Joe
rangerwheelinmike
worked on it today for 15 hours its geting close!
need to build shock mounts front and rear
build front drive shaft
blead the brakes
put oil in the axles
and mount my tires!
Kyle
rangerwheelinmike
rangerwheelinmike
all thats left is rear shocks powersteering flued, put the belt on the motor and mount my rear tires!!
rebel 4x4
Quote from: TRENT on April 06, 2012, 12:53:07 AM
dont forget get it outta the garage
Got 1 1/2" of clearance from the roof to the garage door. We"re good!
rangerwheelinmike
Quote from: rebel 4x4 on April 06, 2012, 03:52:31 AM
no we have 1/2 in of clearance ==roll
burlyq
#33
I've replaced 3 sets of radius arm bushings in my Bronco's, or should I say Les Shuab did, two sets of axel pivot bushings, not to mention constant alignments.  Thank you TTB, you will never miss that garbage. Anyhow that thing is looking stout.
rangerwheelinmike
well mine was a 2000 so it dident have ttb it was torsion bar ifs i have a 5.0 in it so i keep brakeing cv shafts and this truck dident have a steering box it was rack and pinion so i had to put on in it
rangerwheelinmike
well took it to the bog today it all seams to work fine but now it wont run no fuel presure so i need a pump and i also melted a powersteering line on the header and almost cought fire!
Tex
that truck looks awsome short and stout
rebel 4x4
It did pretty good for not running right until the ps line melted.
jbeery78
Very cool build!! Looks like a lotta fun!!
They said buy something you can afford... so i bought a FORD
