Dana 60 swap
Started by haydenlloyd88, March 05, 2012, 03:03:53 PM
Red97
drivers side spring plate the 2 holes for the bolts are closer that what a u bolt would be.
on the brake lines depends on the callipers. older ones standerd size banjo bolt. and newer callipers are metric, witch is smaller banjo bolt that will work with 1/2 ton and 3/4 brake line.
Top plates are what the ubolts go into on top of springs
Quote from: haydenlloyd88 on March 05, 2012, 10:53:45 PM
Quote from: 4x4xdodgeman on March 05, 2012, 10:09:28 PM
you just have 4" lift right?  if so  you just need to adjust the drag link so you have the same turning both ways.   you can buy the steering block for the 60 later.  you will need the top plates for the 60 front end.
Yeah just a 4 inch. And top plates? Sorry I don't know much about drive train work.
haydenlloyd88
Looked up these lift blocks, what the purpose of that middle insert and what is it made out of?
It puts pressure on the kingpin spring.  Steel
haydenlloyd88
I can't seem to find a sight that has that lift block in a 4 inch, anybody know of one?
I have a 3inch on mine with 6 to 8 in lift and its good.  Don't want bigger then that imo
haydenlloyd88
Quote from: Blazin40s on March 07, 2012, 05:37:39 PM
On alright
haydenlloyd88
Would a 2.5 inch block work?
