lincoln lock a 9"
Started by fast78ford, April 06, 2012, 01:18:15 AM
fast78ford
anyone weld the spiders in a 9 inch ford? how?
not in a 9 inch but we've done 10 bolts, 12 bolts, and 14 bolts.. just pull the side gears and fill in 2 teeth on each side on both gears
jbeery78
Quote from: TRENT on April 06, 2012, 01:29:11 AM
Im sure someone has
my opinon would be to just buy a spool, you can get them for like $20 for a 9in, wish they was that cheap for other axles
Just as easy to weld... i welded my 8.8 with 110 welder works just fine
jbeery78
 9 in spools are dirt cheap and fool proof tho   ;D
blasterguy911
yea you can get spools so cheap. because a lot of the race car guys use them i believe.
1972 bronco
fast78ford
anyone got one layin around?
Bo Duke
Unless you have a 9" with an open carrier you cant really.....  Gunna have to buy a spool or some sort of mini locker.  Full spool is the way to go, 9" are so easy to set up its not even funny!!
rangerwheelinmike
i just went threw this you cant weld them becouse the spiders are in side the carrier you cant even see them i bought a spool from speedway motors for 22 bucks they also have one for 16 bucks but its not hardend i would get the better one
31 spline
http://www.speedwaymotors.com/Premium-9-Inch-Ford-Mini-Spool-31-Spline,34360.html
28 spline
http://www.speedwaymotors.com/Premium-9-Inch-Ford-Mini-Spool-28-Spline,34367.html
ive welded  many of 9 in . all you have to do is  take it in half. take the  spider out  and  weld the  axle gear  on the  2 sides.   if you  take the  ring gear off there  3  plilps headed  screw holding it togther.  split it  like you  do a  14  bolt.
fast78ford   if  you  want it  welded  bring it to me. ill let you  weld it. ill show you  how to split it.   send me a pm ill give you me  #
rangerwheelinmike
Quote from: Ranger Dave on April 06, 2012, 07:15:44 AM
mine dident have screws it was pressed I had to press it apart in the press
