400th internals
Started by Jthomas, April 06, 2012, 02:36:26 AM
I have to get this upgraded/rebuilt. I can get it done alot cheaper if I buy the parts. What exactly needs to be upgraded to handle more torque and hp? Like parts do I need to order?
Bo Duke
How much hp are you planning on running???? TH400's are no joke, their pretty stout stock.  If your running something with Hi HP, you can upgrade to a 36 sprag one way clutch and direct drum. also a billet input shaft and a shift kit.
frdzila
spagless, reverse manual valvebody, fully brazed/welded torque converter. seems to be what all the big power guys run.
Quote from: Bo Duke on April 06, 2012, 04:06:17 AM
Running 800+
I'm using the reverse full manual valve bodie. Where can I find the other parts?
http://www.transmissioncenter.net/350_or_400_high_performance.htm
This site has all the parts I need for sale. Scroll to the bottom and check em out. Like $250 I get all the upgrades. Look at their prices and see if they as too much, idk what a deal is.
I have a th475 same as 400 but has straight cut gears that are stronger,  its a 2wd  reverse went out on it, ill sell if your interested,
Quote from: michigan maniac on April 08, 2012, 06:54:44 PM
No thanks. I already got her in pieces, just waiting for the parts. And mine is a 4x4 trans.
