2001 6.5 TD in savana van
Started by bmwallace_88, April 16, 2012, 04:35:52 PM
bmwallace_88
looking for some help with my 6.5, kind of new to diesels, getting a code p0251 which is a fuel metering circut a.   I heard it could be the ECM, (which i dont think so because it will eventually start) the IP which i could see that kind of being it, since the van has 350k miles on it, the PMD which was doomed from the day it was made, or a crank sensor?
ok so now heres the run down, i was driving to work, and it died, wouldnt start, cranked for a bit, and i figured screw it, gave it about 1/4 throttle and it popped off, so it makes me think the crank sensor maybe? i know on my GAS van when the CPS went out it needed the fuel to be pushed to get it started? any diesel techs out there mind shedding a little bit of light on my problem here? thanks for the help guys, as always :)
check out dieselplace.com thats where I go with all my diesel questions.. I would say the IP with that many miles on it the low sulfur diesel probably finally got to it. Alot of them are adding a bottle of 2 stroke oil at fill ups to avoid burning up pumps.
bmwallace_88
Thanks ill check that place out. i thought it might br the ip foudn a reman with a pmd package aand a few other parts for 1000 i dunno if i wanna replace all of that right yet. will check out that site though  thanks again
I just put your code into their search and came up with this... not sure if it will help. ==dunno
http://www.dieselplace.com/forum/showthread.php?t=416894
