can i clear 44s?
Started by Jthomas, April 18, 2012, 09:56:50 PM
so i have a 88' k5 blazer with 6'' suspension and 3'' body.
i figured the biggest id be able to go would be 42''. i have 40s on it right now.
but i just say a 88 pickup on CL with the same type of lifts. (6'' sus. 3'' body) and it was sitting on 44s.
would i be able to clear 44s?
what about frame rub?
thanks
Has to do with your wheel backspacing and if the body of the Blazer is sagging on the body pucks and such . . .
Measure how much room you have with your 40s. Every truck is a bit different with clearances.
another thing to think about is how much cutting did they do ???  There's no way they put 44's on that body style truck with 9" of lift without cutting and I don't think you can either but I could be wrong (there's a first time for everything) loll
I had 8" susp and 3" body lift on my '86, lots of cutting to clear my 44's.
Quote from: Bowtie972 on April 18, 2012, 11:25:58 PM
ive always heard at least 12"+ for 44's. better to have more then you need. wouldnt want to cut the p00 out of those 44s ive heard there not cheap loll
if you use bushwacker cut out flairs you will fit 44s or at least thats what Im told...  I have 44s with 4" lift but lets just say it took alot of cutting and work! lol
I'd didn't appear that it had been cut,(from what I remember)  but I don't want to cut my body at all.
it doesn't seem that the rear have been cut. but the fronts for sure.
Yep those been cut... and they rub bad. lol
you wont be running 44s unless you buy more lift or just trim..
yea that's what i thought. lol. cuz I've never heard of it happening either. cuz like u said. I thought u need like 12"+
I have aways trimed so I didnt have to have a super tall truck.   I like it low and fast! lol
CBakes
I had 11" of lift on my K5 and tore the heck out of my Fenders. I also have cut a fender flares and still hit when the frame and body articulated. I just went up to 14" this week and it looks like I'm finally gonna clear them while wheeling. I took about 4" of rear body sag out too.
yea I'm just Gunna keep it how it is. maybe block the springs an inch or so if I ever want to do 42s. but other than that. I'm happy as a clam.
I have an 85 k5 with 15 inches of lift  and my 44 inch boggers look like they should clear pretty good, but I'm still gonna flex it out slow just to make sure!! Cuz I have brand new metal on the front and don't wanna cut it either,
Also keep in mind that not all tires measure the same height, example, my 44 inch ground hawgs were smaller then my 44 inch boggers,
