cross over question
Started by bbr528, April 22, 2012, 04:38:04 AM
bbr528
i had planed on using 5/8 grade 8 bolts to bolt the rod ends to the pitman arm and to the high steer arm   the high steer arm is set for double sheer but the pitman arm is not
does any one know if the 5/8 bolt will be strong enough or should i buy a heim that uses a 3/4 bolt? ive already got the heims that use a 5/8 bolt but im not sure with the 44s if it will be enough
thanks
I used 5/8's single sheer with 42's on my jeep, you won't break it with a stock steering box the only time you may have an issue is if you hit something hard with the tire/s but this is just my ==2cents
bbr528
