double cardan joint question
Started by nauss, April 22, 2012, 11:14:38 PM
nauss
anybody ever use a double cardan joint on the rear driveshaft? my driveshaft angle is 30 degree and very sketchy on front u joint so i am considering using one. it is a trail rig only, 91 s10 blazer 350 sbc th350 turbo np208 on 44s any other advice will be appreciated thanx for reading.
nauss
tom woods sells a OFF SET U JOINT    gives like 5 degrees more angle   up to 40 *  60$ each  plus shiping i just got 2 of them   .
  Also you can use wedges to roll the axel up or down   from 2-8 *  to help out
  also lower your tcase mount down more
i just drop my tcase over 3"   rolled the front up 4*  and rolled the rear down 6*       the wedges are like 25$ a set    but you may have to redo your leaf spring center pin at this time.
yes you can use them in the rear they work fine I used to use one on my jeep because of the driveshaft angle
Quote from: Mudbuster on April 23, 2012, 12:02:53 AM
X2
nauss
Thanx for all the info guys I'm just one step closer now
nauss
BigBlockBlazer
The offset ujoints are not for street use they vibrate bad.  A cv in the rear requires the pinion to be rotated up and pointed at the tcase.
