WINSHEILD WATER SPRAYER'S?????????
Started by the kandy shop, May 04, 2012, 09:36:06 PM
the kandy shop
im wondering what type of pump i could use to make some winsheild sprayers for the truck...gonna run another fuel cell just for water, but dont know what type of pump to use???
71460frd
Get a little yard sprayer from tsc tank and pump all in one
i used a bilge pump from a boat.  Not real high pressure but lots of volume.  It works great for me
mudboggincrazy
i hads a buddy that had a holley blue fuel pump hooked up 2 his squirters and it put a lot of psi out almosted washed the window without the wipers on lol
AFurg85Chevy
How are you applying the water to the windshield? Out of the stock squirters or did you do something different across the top of the cab?
Quote from: Bowtie972 on May 06, 2012, 02:38:44 AM
mudbillyredneck
Quote from: AFurg85Chevy on May 13, 2012, 07:26:34 PM
I make a piece of tubeing  inside my LUND VISOR ....with lot's of 1/16 holes along the bottom , then plumb it down the a piller and out back to the tank
1/4" Pipe nipples and tees.  welded angle iron to the pipe and bolted thru cowl. copper tubing and compression fittings for the squirters
I just mounted a 8gl tank in the back & a small pump in the cab (60psi) & some pvc pipe in the visor, works good.
