bogging season 2012
Started by Crazymays77, May 12, 2012, 12:51:32 AM
well went to 1 bog this year and the motor is acting up and i really dont want to go buy another motor or spend a lot on this motor. going to pull the front apart and see if timing chain is bad. if its going to cost a lot I think I am going to take some time off from bogging and going to the mounds. i can use the money to do other stuff and get things done around the house. so if you dont see much of me then you know why.
crimedog70
sorry to hear corey   its been that way here to
good luck man, what motor are ya working on man?
those are popular motors... which gen is it? the old style or the newer one? if i end up that way i'll give ya a hand if ya want man
its a 93 old style. I'll take any one of them just running good and i can swap my heads so my intake will work. i have had 2 people over here and we tried everything. its just worn out and needs parts or i need a diff motor.
i'll see if i can find one for ya cheep
well it looks like i found the issue. should have known. looks like that brand new cdi box from summit racing took a crap. took the stuff out of the dist and put the stock stuff back in the dist fired right up and i can time it normal and it seems to run smooth when i give it throttle. cant run it long dont have coolant system hooked back up yet. but i plan to test it out tomorrow and see what happens going to contact summit racing and get a new cdi box and see if it works if not going to return it and get my money back. kinda sucks i liked having a rev limiter.
this guy
i think im having the same problem with my 94 blazer wont start unless i dump gas in the intake then will run all day just not good  and wont restart with out dumping gas in it not really sure whats going on
my 93 blazer did that too. i think it has to do with the fuel pump might want to check into that.
this guy
new pump filter and plugs
idk then maybe injectors. i didnt mess with mine i sold it. had other issues too didnt want to deal with it.
this guy
yea they have problems with the maxi injector and some other stuff they had recalls on alot of the fuel system
put a intake and carb on it prob solved lol.
