u joints
Started by motoxman, May 13, 2012, 12:05:05 PM
motoxman
Im running 38.5 cut boggers and im going through u joint like no other. Is there a way to prevent this without going to a different tire?
Probably has somethin to do with your driveline angle - can you post pics..?
motoxman
is it your wheel joints     /or your drive shafts        and what you got for axels     are your  yokes lined up    ujoints come in bigger sizes   1310 1350 1410       are you breaking or just wearing them out   ?
motoxman
60 front 14 full floater rear. 1310 front yoke. Not sure what the rear is. I have 4:88 gears. And its just plain snapping brand new u joints
Quote from: motoxman on May 13, 2012, 01:42:22 PM
Name brand of the ujoint???
snappin outta the box or after a few runs ???
takin the yolks out or just the joint ???
motoxman
Ive used autozone joints and percision joint and they will break after a couple hours at a bog. Im tryen to post a pic so u guys can see what im worken with
bigdawg41
i only run spicer, no problems
i prefer precision non greasable
ok but witch one are ya blowin   then  front or rear     who made your shafts    back to your shafts
are your ears in line with each other       they have to be or your shaft is binding/  at different times
are you runnin alot of angle     what type of rig  ( truck   )
motoxman
The angles are a little steep. And its a single cab short box
if you can email or text pics i can post them for you. crazymays77@charter.net or 9898630769
motoxman
I can send pics but there are no drive shafts in it right now
motoxman
How can i post a pic to this page?
motoxman
Ill just send em to you
here are a few pics he sent me.
tha last pic  is the the rear looks like you need to shim it up  roll it up it'll help your angle  put like a 4-6 *
Quote from: BIG DOG on May 13, 2012, 09:18:25 PM
x2
on the front, dont over tighten
