Mudder - $800 (Albright Shores (Beaverton))
Started by Bigdaddy, May 15, 2012, 03:09:23 AM
http://saginaw.craigslist.org/cto/3014870345.html
This is a fullsized Ford Bronco frame with a 302 motor and a automatic trans. Runs pretty good, does need a fuel pump it is getting weak and needs a front drive axle on the passenger side. It has 35's on it not the best but will work the front tires as you can see are cut. Its a home made body with tubular steel for the body frame. So it is light weight. I took it on trade and the starter was falling off was told everything else was good other than what I listed it seems to be. I was lied too but I am telling you what I know about it. It should be lots of fun with a little TLC. I might take partial trades. All you can do is offer and I say yes or no. I dont always check my email but you can email here or call (989) Four35-Two 380. Rick
Pics arent the best but all I have.
85cHeavyMetalBogger
