Th400 assembly help
Started by Jthomas, May 23, 2012, 03:57:01 AM
Ok, so I know how to put these things together. I just did a complete overhaul on the trans today, but the only thing keeping me from finishing is installing the direct drum. It keeps getting hung up on the intermediate clutches. The drum slips on to the sun gear shaft, but once I get there it's hard to spin the drum because it's lubed up and then I'm spinning the rest o the internals. I tried to line up the clutch teeth as best as I could, but I have to rotate the drum a bit to get it to drop into place on the shaft. Wich un-alignes my clutch teeth. Then like mentioned earlier, it becomes really hard to spin everything, and the weight of the drum is forcing all the clutches to spin when I rotate the drum. I don't want to push harder cuz I'm afraid to break clutch teeth.
Know any tricks to get this bad boy on there?
Any tricks or tips would be greatly appreciated.
Thanks.
I have a book on these I'll go try to find it. If I dont repost tonight I'll try to figure out a answer for ya tomorrow.
Quote from: lilred on May 24, 2012, 03:11:20 AM
Thanks
Nevermind. Just found the book it covers th250, 250c, 350, 350c & 375b
my broke ass ford!!
mudbuster or betterbeaters should know some tricks
Quote from: my broke ass ford!! on May 24, 2012, 08:23:40 AM
yep take it to a pro to do it! if you dont know what your doing you can hurt more than you fix!!
Quote from: betterbeaters on May 24, 2012, 01:27:25 PM
No $. I need the tranny done ASAP, it's summer time and I still don't have a job. I need this truck movin NOW.
I can rebuild 700-r4s, th350s, th400s. I've done them befor, just can't get the drum to settle in the clutch teeth. Or else I'd be done!
Ill try to call my trans guy later and ask him for some tips...
Quote from: betterbeaters on May 24, 2012, 02:15:27 PM
Thanks!
I'm just trying to get the direct drum to settle on the intermediate clutches. Other than that, I'm good to go. TCI manual valve body kit will be here today! :)
dirtydog
ull never learn if u dont try n trannys r not as hard to do as everyone thinks. JMO
#11
Quote from: dirtydog on May 24, 2012, 02:50:27 PM
Exactly, I have rebuilt this thing from top to bottom with new Kevlar bands and better clutches. Got the 34 element sprag. Replaced all the bushings and seals and rings. Took the burn marks off the drums. It was a junk yard tranny.
Ok I got it!
How do I measure the clutch pack clearance?
got her done day befor yesterday!! just got the new 205, now im bout to do the twin stick mod, then mount it, bolt em in, and put the motor in, and then shell be back on the road.
thanks alot!
