shift cable
Started by wayne w, May 25, 2012, 03:32:41 PM
wayne w
anybody no if a b&m shift cable will fit a hurst shifter?
HellYeah4x4
im using a hurst shifter with a cable from a b&m...should be fine
rangerwheelinmike
Quote from: OHEARN.2012 on May 25, 2012, 03:56:07 PM
Try it and see?
ain't got one to try wanna give us yours? Loll
dont got one any more lol
mudboggincrazy
the 1 time i had 2 use the cable for a hurst shifter  the bolt hole  that holds the cable at the shifter was  2 small i drilled it out and it worked fine on the b&m shifter i had thats all that i found 2 be diff in the cables
