which direction to go with build???
Started by rayning lead, May 28, 2012, 06:56:49 AM
rayning lead
I just put my new motor in built sbf it's in my only vehicle 91 f150 9" lift 33's everything on truck is stock I like to go out and play with my truck but its not that capable it has gumbo mudders on it and I can easily clean them out but I have p00 for clearence and open diffs but if I go bigger tires like 38's my axles Prally won't hold up at all and I'll have to regear which isn't cheap or easy from what I have heard and I can't afford axle swaps. But the big thing is I want to keep it my dd but a very capable weekend warrior so what do you guys think?
its a FORD thing you wouldnt understand
Get some one tons.  Only way to go, if u wanna play and drive it home
daily drivers dont make good toys...
start with a winch, than buy a cheap car so you can get to work still
rayning lead
Well I only drive 6 miles a day so it really isn't a dd and my wife has a brand new car I would just still like to drive it around through town every now and then
when i bogged my dd (often) i would run bfg at's all week than put my boggers on for the weekend. saved a lot of wear. so i would say start with the basics, good recovery points, clevices, fire extuingsher, maybe weld the rear if no money for lockers, and i definetly would look around for a nice rack to put behind the drivers window to keep bad things out. its not fun if its not safe!
Quote from: marshall on May 28, 2012, 03:36:45 PM
x2
rayning lead
I was going to get a locker anyways and maybe some 35 or bigger but what will these axles withstand I know when to put the foot down and when not to I don't like fixing my truck after every weekend so tire size is important I have lift and power but only 33
4x4fun
Quote from: Blazin40s on May 28, 2012, 12:08:28 PM
hes speaking from experience, we both drive our rigs there, wheel em then drive em home...  worst thing is if you wanna play and still use it as a DD, you HAVE to maintain them more then normal..
GotMud?
as ive always said, go big and still drive home...
x1000 on the headache rack, Im sure puttin one on mine!
