Np205 problem
Started by Jthomas, May 29, 2012, 04:59:44 PM
Just traded my twin stick 205 for a plain one. I I start the twin stick mod on this one, and come to find out, there is a handfull of roller bearings in the bottom of the case, and pieces of a bearing assem. The front driveshaft yolk was loose, I just thought it was the nut, (that was loose too). So I think it's missing a bearing on the front output side. The roller bearings in the cover for the gears are good. But I don't know where this ate up bearing came from. Any ideas? I'd post pics, but I can't.
Thanks.
if you can text some pics, 810-936-1682   Ill take a look and post em for ya.
also did you split the case yet?  either way your guna have to, to find  out where it came from and to inspect gears to make sure they didnt get all chewed up.
Pics on the way. Luckly the roller bearings are stuck in a clump of bearing grease, so nothing got sucked through the gears.
found it..... It is the front shaft rear needle bearing....    pics up in a few minuites :)
pics
pic 3 is the front shaft outter bearing, so yea after a little research and calling up my old man loll   it is the front shaft inner needle bearings
Still need help trying to figure out what bearing it is.
