mandrel bent headers
Started by blittle913, May 30, 2012, 09:33:45 PM
blittle913
Is it really worth the money to buy mandrel bent headers? Ive heard good reviews on elliot headers but they are not mandrel bent. Schoenfield are but they run around $100 more. Is it worth it?
When in doubt, throttle out!
4-play
71460frd
I do not recommend elliot motosports took 1 months to get mine then paid a local guy to fix them.
Depends what your building...if your going for every ounce of power building 1000+hp then definitely. If you building a 400hp backyard bogger i doubt youll ever notice the difference.
blittle913
Probably gonna fit into the 400 horse backyard bogger class....thanks
Thumper
try dec headers. that is where I got all three set of my headers, good price and good people to work with
THE D&D CREW
RaZiN KaNe
Quote from: 4-play on May 30, 2012, 10:14:25 PM
YES
compression bent headers drastically reduce the flow...even if it is 400 horse id go with a set of shoienfeilds
B.G. Grounds Maintenance
sdsmas1
whatever gets your truck out of the garage!!! put the 100 you saved into your gears and get back the couple ponies plus some.
