Ignition/ distributor issues
Started by haydenlloyd88, June 02, 2012, 11:08:21 PM
haydenlloyd88
I've had about all I can take with starting and ignition issues ==pissed
The truck has a brand new distributor assembly. The only thing that wasn't replaced was the ignition coil on top.
The truck ran good for a few days but then recently it started to run like it's missing a few cylinders. So today I took the cap off the ignition coil to see if I had a bad connection. I unplugged the white conector, looked fine so unplugged it back in and now it won't start. I even replaced the coil and it still won't start. Really frustrated and need help.
haydenlloyd88
Quote from: Blazin40s on June 03, 2012, 01:30:01 AM
Module?
Think that could be? I was wondering that but it's a brand new module I believe
jbeery78
Pickup coil is possible... just dropped a new distributor in my dads dodge and the air gap was so far out it wouldnt start... adjusted it to spec. Fired right up.
haydenlloyd88
Quote from: jbeery78 on June 03, 2012, 02:20:21 AM
But the truck was running fine. What could have happened when I unplugged that coil that could cause the truck to not start
The wires that come from the pick-up are very fragile and couldve got broke when you unplugged stuff.. Im just guessin ==dunno What are we workin on..?
haydenlloyd88
Quote from: old school truck dude on June 03, 2012, 11:59:32 AM
84 chevy dually
sounds like pickup is bador mabye coil failed.
wondering...why did you put a new distributor in to start with? previous problem?
K.I.S.S. it!
start with..
1. does the wire even have power to it ???
2. sure you plugged into the correct port (ign. not tach)
3. connector - corrosion, dirt etc.. @ the connection.
it ran before..
you touched certain items to inspect.
now it don't run
good bet it's whatever you touched.
haydenlloyd88
Quote from: marshall on June 03, 2012, 02:35:18 PM
Previous problem was a bad ignition coil, and we replaced everything around it till we figured out the problem. But then we put a used one in the new distributor.
Sounds like u just answered yer own question man
haydenlloyd88
Quote from: Blazin40s on June 03, 2012, 04:45:32 PM
yeah but i repaced the coil last night.
but anyways i fixed it, turned out the power wire burnt out.
dont know why i didnt check that first. ==doh
