What ring and pinion should I run
Started by cato699, June 09, 2012, 02:35:28 PM
cato699
Just thinking about going to a bigger gear since I just broke my front ring... Ok just wanted some other thought's on this.... I am running a L98 with mild cam to a Th350 tranny to a NP205... I have 1975 Dodge Dana 60 front and Dana 70 rear and 44x18.5 Ground Hawgs.... The axles came with 488 gears in them so I can go up to a 7.17 gear if need be but I am looking at a set of 6.17's.... What are your thoughts?
6.17s are sweet, had tractors with a set, they worked great
that much gear is easy to take the pinion teeth off. you only have 2 teeth touching the ring gear.
Quote from: 4x4xdodgeman on June 09, 2012, 02:42:42 PM
i had them in a lightweight jeep, putting them under a heavy fullsize truck ya might have a problem.
cato699
I would like a lot more wheel speed but I have never ran a bigger gear in it.... They are going in the blazer. I was thinking about breaking as well but was not sure..
Squirell
Quote from: cato699 on June 09, 2012, 02:49:56 PM
you arent goin to get more wheel speed goin to 6.17
cato699
Quote from: Squirell on June 09, 2012, 02:54:51 PM
No?
cato699
Quote from: TRENT on June 09, 2012, 03:10:42 PM
people dont seem to understand that
going with a lower gear gives you more rpms and makes it easier to spin the tires but the tires wont spin as fast
say for example, with 4.88 gears at 6k rpms your going 50mph
with 6.17 gears at 6k rpms your only going 30mph
you can spin the tires easier and get more rpms faster but when your on your redline your tires wont spin as fast
That make scene. So wrong wording lol. I want to spin them easier.  Was thinking about 5.86's as well.... I have a friend with almost the same set up but he has 5.38 and he don't seem to have the spin I want..
cato699
cato699
#9
Thanks Trent... Anymore input out there?
get a 208 and stay with 4.88s  and it will way cheaper even if you have to pay to swap trans outputs..I ran 4.56s 208 cut 44 hawgs and with my little motor I could run 1st and alittle  2nd! with the bigger motor 2nd all day...
cato699
Been thinking that one to Betterbeaters but I am very fond of the strength of the 205 but it is a thought man thanks.
500hp 6+ years 208s are stronger than most think! I have never liked 205 and wont run them lol
208 or 241
cato699
If I went to a 208 wouldn't I have to change the drive shaft as well?
cato699
My front has the plate on it so I would think so.
depends on how you put the 208 on if you use a custom 203 adaptor the front should work and the rear will need to be slip yoke if the 205 is slip it may work!
cato699
Rear is not a slip so I would have to change a lot of stuff but ok its a thought man thanks... Oh and I am still looking for a used 488 gear out of a Chevy or Dodge dana 60 to get me by.
cato699
Squirell
Quote from: betterbeaters on June 09, 2012, 03:52:24 PM
x2!!!!!!!!!!!!!!!
