cutting weight
Started by 91 k1500, June 11, 2012, 10:20:50 PM
91 k1500
where are people cutting weight to make there rigs lighter? i am gonna cut the bed floor out, cut the tires, shave any and all brackets off the truck i can find not in use, was just wondering what else guys are doing to lighten things up? bigger engine is not in the budget this year so i am looking for other methods to go faster in the mud lol.
this is a play bog truck so i dont have any rules to follow etc....
Take the whole body off, And just run a seat loll
mudbillyredneck
you'd be surprised how much old dried up mud can weigh  ==doh
skin everything! box skins and front fender skins anything in the cab you dont need  shorten the truck will help too
91 k1500
how many guys ditch the hvac and dash? i winter wheel now and then though
Quote from: 91 k1500 on June 11, 2012, 11:55:54 PM
Im usin my a/c condenser, evaporator, whatever for the transcooler but keepin the dash in it, theres alotta p00 up under there loll
I have no dash no heating nothing but bars and a shell!   i am still gutting move everyday putting my cage in then anything not in use is gone..  only thing in my truck is a shifter, steering whee, seats and gauges
Gut the whole.interior u don't need it.
get rid of the glass, and heat. make a sheet metal visor. cut the inside of your doors out, use the outside handles. cut the top of the doors off also. ditch the wipers, radio, exhaust, mat off the floor, mirrors sun visors, spare tire...
91 k1500
that covers the body... what about axles etc? i already went disc breaks on the 14 bolt...... been thinking about pulling the hubs and turning them down in the lathe.... i removed the fuel tank and went to a fuel cell.... thinkin about ditching the core support and building a tube one....
14 bolt shave kit. Aluminum hubs front and rear. Aluminum rims.
TOMAC
Start running and eating healthy lol
Quote from: betterbeaters on June 11, 2012, 10:40:27 PM
Fill the tires with helium. ;D
91 k1500
funny guys! lol
anyone else?
kick the ole' lady outta the truck.. that's at least 100 lbs.  ;D
Fiberglass... panels, all you can replace. it's gonna cost ya though.
and I agree w/ Trent.. dont sacrifice strength for weight.
What size tires you running? What gear ratio in axles?  Are you running any type of ladder bars?  Just like drag racing, getting good traction helps you go.faster!!
cut your tires you can shave alot of weight there and its less rotating mass
