mill and lathe work coleman, mi
Started by 84silverado, June 14, 2012, 01:23:34 PM
84silverado
i am posting this for my dad. he is a machinist and has over 22+ years experience. Yes he actually went to school for it, runs everything from that manual lathe from the 40's to today new CNC mills, has saved his company's ass a couple time when others have f%$ked up. can weld steel or aluminum. has everything to do anything. can either pay cash or work out trades. if you want proof of his work here are some pictures.
call (989)465-6824 ask for jason
fyi, the first picture is for the steering on my truck, he made the ones of the left after mine, on the right, bent
84silverado
#1
since i now out of bootcamp i figured id bump this on up. and yes guys i built my whole truck in this guys garage, all my parts were custom made, even my clocking ring for my transfercase, driveshafts, and pinion brake mounts. you want anything custom, it can be done.
84silverado
can put centers in tractor rims for your rockwell/clark/whatever your runnin lug pattern....weld that broke piece of the transmission case bellhousing back on weither steel or aluminum
Torg37
I called the number that you listed and left a message, but no one has called back???  I would love to help a member out before going to my local machinist so if you want the job please give me a call.    Jerry (989) 205-9422
84silverado
Ill get ahold of him and let him know to get back with you
84silverado
He off work for awhile so anything that comes in will be get done quickly, still doing fab work on anything a everything including aluminum!! Just called home he putting in my SCS in a cradle right now makin shafts and mounts and other goodies, if ya need it make or done, welding or even cut up, got the plasma cutter up to 1 inch :)
Hmm might have to call, was thinking of getting 14 bolt ff hubs turned down, then welded and redrilled for 6 lug
84silverado
#7
He's got the equipment to do the job. No problems there, if he don't answer just leave a message cause I know te only reason he working on my truck is he got tired of the parts taking up space in his garage loll
84silverado
#8
Anybody need a clocking ring? Spacers? Special adapters for special goodies? Fix the TGW boo boo? Need some brakets for mounting rocks to that leaf spring pack? anything like that? He just put traction bars on my truck today too. Damn good with edelbrock carbs also
84silverado
