dodge 360 wont spark?
Started by fast78ford, June 15, 2012, 03:09:29 AM
fast78ford
my friend took a running and driving /6 and 4 speed out of his 83 dodge truck, and replaced them with a 360/727 set up. we hook all the ignition components up as they were with the /6 and no spark? when using a test light both pos and neg terminals on coil are hot? what would cause this?
Quote from: fast78ford on June 15, 2012, 03:09:29 AM
pick up coil in the dist. under cap and rotor. 2 screws hold it in.
fast78ford
i figured youd be the one to respond lol
will let him know tomorrow
thanks
cody
jbeery78
Quote from: Flat_Black on June 15, 2012, 03:28:58 AM
X2 make sure the air gap is adjusted correctly, just dropped a new dist in my dads dodge, then had to screw with the air gap cause it wouldnt fire.
fast78ford
does the pick up coil have anything to do with the neg terminal on the coil being hot?
