Drive Shaft Brakes
Started by BC775, July 04, 2012, 04:43:51 AM
BC775
Im building a new bogger and im curious if any one has ever set up a brake system that is mounted right to the back of the transfer case at the yoke. ive seen alot of parking brakes put there, but i havent found any disc brake set ups yet and im not 100% sure if it will work. be nice to keep the caliper some what out of the mud. any one have any ideas or thoughts ?
It'll work it would be the same as a pinion brake on the axle.  Just rememberIf you break a driveshaft, axleshaft, or anything else behind the brake you won't have brakes.
71 Highboy
I put one on the back of my 205, works great. I you break the rear shaft it will still stop as long as you are in 4 wheel drive, you are stopping the tcase not the wheels
TNT BOGGING
BC775
ok sweet, ive never seen one mounted there, and ill be good i dont plan on taking the truck out of four wheel drive. did you build all your own brackets?
Puddlejumper ran one on his truck and made it himself...pm him
71 Highboy
Quote from: BC775 on July 04, 2012, 05:25:46 PM
No i bought mine from a guy that went to 2.5 tons, I know that the caliper is off a 90s lumina and the rotor is off a 80s 1/2 ton chevy pickup. If you pm me your number i can send you pics mounted on the truck
TNT BOGGING
