Holley 600cfm, vac 2nds, man choke
Started by Yankee Hick, July 10, 2012, 07:58:59 PM
Yankee Hick
i bought this carb with the engine i'm building.  after looking up the casting number, i find out that it's a MANUAL CHOKE!  crap!  this is going into my daily driver, onto a 355, Edelbrock (sp?) Performer intake, stock heads (ported), and a .465 Summit cam.  How hard is it to run a cable into the cab to keep the manual choke, or should i trade it for an electric choke model?
dumber question.... is the 600cfm big enough for this motor?  keep in mind, this is a daily driver, weekend fun runner.
I'm not stuck!  I'm just temporarily parked!
1991 Chevy K1500.  350cid, 5spd manual.  No lift "yet," with 33x12.5x15s.
the carb is good size for your motor. far as the choke gose run a cable or change it over to electric choke, its easy to do.
carb sixe is just fine for motor.... Running a cable is easy to do, get one them choke cables for a lawn mower at ace or gillroys  there pretty cheap and work just fine...
Yankee Hick
thanks!!!  how about this question:  would a 670 truck avenger carb be better?  i drive it daily, but i like to get on it, and i like going to comp bogs and whatnot, and bounce around quite a bit.
mudboggincrazy
i ran a 600 holley on my bogger with no problems it wqas a 4130 series all stock and i had no problems at all with it
