where is coolant going?
Started by Captn. J, July 12, 2012, 02:42:36 AM
 my brother has a 02 taraus    he said  ONLY when he use ac   the coolant will go low and it will overheat   but when ac not is use    all is good     what is the problem?
black07ss
 ??? It's a ford  ???  More info.  How often does he NOT use the ac seen as it has been freakin hot for a little while now.  Just thinkin it still is using coolant even when ac is off and just hasn't really paid any attention but maybe his secondary elect. fan is not turning on to help keep the engine cool.
Quote from: black07ss on July 12, 2012, 03:48:32 AM
x2    the fan should automatically kick on when  the ac is on, also the ac puts a lot of load on the engine, so If he is doing a lot of idling with ac on.... there will be an overheat issue right there especially if fan isn't kicking on.   but I do know them taraus's have a common problem with the head gaskets, so I would start there.    Well really start by looking for any leaks :)
