have a ? need help ASAP?
Started by boggers55, July 26, 2012, 04:05:40 PM
boggers55
How much does it cost to do front and rear breakes on a 82 chevy 1ton?
labor guna should be around 80-100 roughly plus parts depending on what you need.... just pads and shoes or rotors and drums, your looking at around 50 or more a rotor and 80-100 a drum.
do it your self   50$  for the pads   and have the others turned        circle or draves auto. on eastman rd
boggers55
hey bigdog whats the proper way or eaiset way to blead them?
cuz i think there is air in the lines
if you get them   the bleeders broke loose first      and always start with the back ones first    or adjust the rear pads up some also the rear is your pedal   if there not workin right?
