16.9 x 26 to 18.4s?
Started by four_by_ken, August 14, 2012, 04:40:03 PM
Can you use the same rims for 16.9s and 18.4s?
How picky are tractor tires with width of rims?
hghrdnhck
You can use the same rims. If you use a narrower rim it will make the tires taller. If you use a wider rim it will lay a wider foot print and be a little shorter.
Quote from: hghrdnhck on August 14, 2012, 09:16:59 PM
I figured this would be like a typical tire...  I hope this is the case.
I just never hear anyone talking about rim width and the tire bead, etc. when concerned with tractor tires.
