d60 hubs
Started by Kyle, August 16, 2012, 09:17:03 AM
On the dana 60 I bought I was lookin for lockouts and mine has 8 bolts instead of 6 for the lockout to bolt to the hub and the only ones I can get for it are the warn premium hubs and they are designed different from the 6 bolt style.... do I have some dually hubs on it just without the spacer adapter for the dually wheels massive offset? cuz the hubs also taper down when it gets to the wheel studs...
BigWheelBob
#1
Sound like you have old Dodge. 1979-89 versions had external style hubs, with the earlier versions with full-time NP203 Transfer cases having external drive flanges, and later models having external lockout hubs.  The external lockout hub bolt pattern is 8 x 3.960".  The 90-93 versions had internal style hubs just like the Chevy and lockout hubs.
It had some weirdly designed selectro lockout hubs on it. And uf it had lockouts on it already i shouldnt need the full tim to part time conversion kit then right?? Im assuming i shouldnt
yep i have to agree it does sound like that you got a dodge front axle.  and about your last question i would say trial and error time.
thay started with that hub in 1976 for the dana60 30 spline axel shaft. but the dana 70 with drum brakes have the same 8 bolts that hold the lock out on but was 17 spline axel shaft.  if you want lock out its only super winch that makes them now.
this is the hubs that were on there:
http://www.summitracing.com/parts/MMK-11034-01/?rtype=10
but can i use the chevy hubs instead cuz for a chevy 60 i can get warn hubs:
http://www.summitracing.com/parts/WRN-38826/
Quote from: Kyle on August 20, 2012, 06:44:27 PM
this hub is for an external hub set up.  so you pretty much gotta stick with what you got or go with some sort of "full time" flange if they make one.
they make drive flanges but i cant use em cuz this truck is a dd. i just didnt wanna use selectros cuz ive had em in my 44 and they are chinsy and cheap and didnt lock in half the time
superwinch makes a set with lifetime replacement I think? they work good.
Quote from: betterbeaters on August 20, 2012, 07:38:29 PM
I cant find em on summit.... it dont look like their site has em either....
they did sell them? seen them on a buddys truck
if anybody can find where theyre at itd be appreciated. ive had no luck myself...
BigWheelBob
Also, the chevy hub you have listed is for a 3/4 ton, so that wont work for you. chevy, and ford used them thru about 77 or so.
