Need some wiring help. One more question
Started by TAPOUT07, September 01, 2012, 07:58:58 PM
TAPOUT07
Last time I had my bogger out  I must of pinched or broke some wires in my colum bc the key won't work at all. So I just figured I would set it up using toggle switchs. Since the starter was already hooked to one. I just don't know how to set it up so the ignition will have Power to the distributor. Any help will be help full
Will the alternator still work if I run a toggle switch
HOLD MY BEER AND WATCH THIS!!!
TAPOUT07
It's a 82. Heavy with a carbed 350
Put a toggle in line between a 12 volt power source and the power wire going into the coil on the distributor.  Using a fuse in line wouldn't be that bad of an idea either.
TAPOUT07
So wire from battery to switch and from the switch to the coil? What wire on the coil do I go to its a msd dizzy
if its msd look it up online.. and do you have a msd box?
TAPOUT07
Nope no box just a off the shelve msd distributor
Into plug that says batt. I assume its an hei replacement
TAPOUT07
TAPOUT07
it should, as long as it was working before.
TAPOUT07
Yeah it did i just wanted to make sure bc I didn't know if the key sent power to it or something
TAPOUT07
Could some one tell me how I would go about wirin the ignition with a 3 Postion switch. Sorry for all the question I'm not good at wiring
Stop at a hardware and get a single pull single throw switch. No need for anything more.
lilred
let me know if ya need a hand with any of it. I'm home after 6-8ish everyday.
