how big of tire can a 1994 3500 4x4 chevy clear
Started by Andy Michalik, September 14, 2012, 01:17:51 AM
Andy Michalik
so i picked up a dually 1994 6.5 diesel chevy 3500 4x4 it has 245/75/16's on it how big can i go with out front fender clearance problems can i clear a 285?
Jr
285 will clear with not touching the t bars... you can clear a 315 75 16 with t car cranking.. and fender trimming
dogred
3500 dually? have to make sure the tires on rear can keep the gap between them or you use spacers.
HE WHO DIES WITH THE MOST TOYS WINS ----- tresspassers shot  violaters violated  survivers shot again ------ GO HARD OR GO HOME----
Andy Michalik
yea dually i was wondering if i would need rear spacers. I didnt want to crank the t bars up either i like how it rides just want more rubber
dogred
usually if you are using a wider tire you have to use spacers on rear as you cant let them rub each other. spacers are available and generally aroun 250-300. gives truck a different look and my 99 ford actually made its width 8 foot 6 inches wide. you can get tires that are 32 and still skinny which is what i just put on my dodge ram 3500...
