Oil pan hitting crossmember
Started by Jthomas, September 22, 2012, 11:41:03 PM
Jthomas
Tried to put the motor in the truck today. The oil pan is hitting the crossmember, which keeps the motor from sitting in the
Mounts.
You can see how close the holes are to lining up
The mounts ARE THE SAME SIZE AS STOCK. Wtf is the problem here?
Jthomas
Quote from: Captn. J on September 22, 2012, 11:59:27 PM
bigger oil pan? aftermarket?
It is a deep sump pan. But I thought they were all the same up front? Any shorter the stroke will hit the pan?
xjs3667
try switching mounts left to right, if they arnt already marked...  also you could wobble out the holes on the mounts to make the mounts slide down further..... you could cut, notch and weld a chunk out of the cross member or... look inside the oil pan and see whats under there and maybe take some agression out on it with a hammer loll
Jthomas
I thought about denting the pan, but I have a 4.25" stroke. The crank is really close to the pan.
What's the difference in stock pans?
your frame side mounts look to be upside down try flipping them around ==2cents
Jthomas
Quote from: Mudbuster on September 23, 2012, 12:18:29 AM
I thought there wasn't a difference. They look pretty centered.
pretty sure they are offset to one end slightly could be wrong but worth a try before you start slashin and bashin
Jthomas
No doubt. I'll measure in the morning. The guys at summit told me that this was the exact thing I needed
I'd almost be willing to bet good luck
Jthomas
Had the same problem when I did my v8 s-10 years ago. I switched the mount plats around and it lifted the mount holes up about 1''. Good luck!
Jthomas
Quote from: KORNBREAD on September 23, 2012, 02:32:07 AM
You mean swap frame rail to frame rail? Or just flip them 180?
BAD APPLE
Motor mounts are not semetrical to one another flip flop them and u shouldnt have a problem
no rest for the wicked
Jthomas
Thanks alot guys. I'll give it a try.
Jthomas
I measured it, and it seems to me 2.5" from center bolt to mounting bolt on both top and bottom?
Unbolt the bottom halves of the motor mounts from the crossmember. Bolt the bottom halves to the top halves of the motor mounts with the long bolt. Bolt motor mount assemblies to sides of block. Raise engine with cherrypicker to clear crossmember. Put flat plate of correct thickness under mounts. Set motor down. Make sure pan is clear and dizzy aint hittin firewall, and motor is straight and level, and weld it all together. Been there done that many times. ;D
Jthomas
