boxed in engine
Started by sdsmas1, September 26, 2012, 01:00:44 AM
sdsmas1
i want to box in my engine on my 79 ford over winter and was looking to see how any of you have done it. what you used and so on. pics would be helpfull.
Plastic insert bedliners work great!
I'd like to know the same thing, but I'd have to use metal, headers will hang out the side
sdsmas1
yeah, i just picked up a set of uprights so i was thinking metal also. maybe like the tin off an oven or something.
Quote from: sdsmas1 on September 26, 2012, 06:44:33 PM
lol, sounds messy, sheet metal prices aren't bad
HellYeah4x4
ill try n post some pics. i went cheap on mine for now, over the winter im going to enclose the motor with 22 gauge sheet metal. for now i used rubber roofing and backed it with some header tape i had then i took a few strips of sheet metal and bent em to push the rubber out bout 4 or 5 inches away from the uprites. seems to be doing fine with the heat after i ran it around for awhile.
I made mine out of angel iron & sheeted it with aluminum sheeting, 4 peaces, removable top & sides, The bottom is welded on.
sdsmas1
wow! thanks D60KING. looks nice. funny how i thought about using tin off of an oven and it looks like you got one just sitting there.
I don't have a re-located  rad. Hows your engine temps?
check out jwarners build thread
Quote from: Jthomas on September 27, 2012, 01:52:33 AM
It stays cool, I have two radiators & two water pumps on it. It will get hot if you run it hard and for a long time, the radiators are also somewhat covered up in the back just to keep the mud out of the fans. but all in all stays cool.
I can't relocate mine, but idk how hot it will be. There won't be any airflow.  I wouldn't box in the rad, but the box would be pretty close to it. I don't think air would flow right. Even I I put pullers on it, driving on the road I think it will get hot
sdsmas1
jthomas, if i were you id start by sealing the bottom the best you can. and then maybe just seal to your inner fenders. if it dont get hot then maybe start building sides. just my opinion.
sdsmas1
thanks trent, i appreciate the pics
Quote from: sdsmas1 on September 27, 2012, 10:18:59 PM
Yea i agree , I'll have to do that
This is on my winter to do list also.
Inner fenders are going to have to come out I think.
Quote from: four_by_ken on October 08, 2012, 04:42:58 PM
X2
sdsmas1
any one with pics of headers coming out?
