rear end questions 07 sierra?
Started by Blake Scheuneman, September 28, 2012, 10:30:26 PM
Blake Scheuneman
When i turn my rear end is squackin like its welded? Anyone know what it would be. 07 sierra new body style z71
chevv ==dew alll
Before we got to into this, have you done the obvious and checked the driveshaft,u-joints,pinion yolk/bearing, stuff like that for play??
rangerwheelinmike
Quote from: TRENT on September 29, 2012, 01:19:36 AM
Does the axle have a factory locker in it ???
they all do in my grandpas.if the tires spin a little then you turn it will. Be locked up
jbeery78
U joints often squeek when theyre goin bad....
My 08 factory locker will stay engaged sometimes longer than it should, has for years. My buddy told me it was about to break years ago, still hasn't.
Blake Scheuneman
Quote from: jbeery78 on September 30, 2012, 01:51:39 PM
No its not a u joint i know what that sounds like. Its the rear end binding like.its welded and thats that lol. It only did itonce and it hasnt done it again. Hopefully all is good thanks for the info guys
chevv ==dew alll
Z71s have rear lockers in them. I bet the locker was just engaged.
Have you pulled the diff cover off to check that it does have a locking differential?
Should just be a G80 code in the glove box . . .
Jr
Blake Scheuneman
It does have a locker ive just never fekt it do.it befire i didnt know uf i should be worried
chevv ==dew alll
Boggen Joe
I wouldn't worry about it. My 2008 does it at times. My fatherinlaws also in his 2003. If it has over 75k on it I would change the fluid, sometimes it helps, being broke down
Blake Scheuneman
chevv ==dew alll
Quote from: marshall on September 30, 2012, 01:56:15 PM
my 02 ive changed the inside yoke one washer seized on it and it was staying ingauged in the corners  .  a yr later it went again   so we put in a detroit clutch locker   around 100 000 miles    but i snow plow  run it harder than most    ,  it hated  spinnin then the  factory locker engauaged at 50mph  wet roades
My duty was doing the same thing, I changed the fluid and put posi additave and it stopped doing it, bought it at napa it was like 8 bux. was eating tires like crazy
Blake Scheuneman
Quote from: burl on October 02, 2012, 11:32:58 PM
Cool it hasnt done it again but ill do that anyways
chevv ==dew alll
#17
Quote from: BIG DOG on October 02, 2012, 10:23:37 PM
Your factory locker unlocks at above ~20 mph if it isn't already locked. It might try to engage, but it won't. This is where a lot of guys blow up their Eaton lockers, thinking they engage at all speeds.
