Big block chrysler 470cui. Full aftermarket engine SOLD!!!!!!!!!!!
Started by moparhorse, October 18, 2012, 03:28:17 AM
moparhorse
Serious buyers only.
Mopar mega block
Billet crankshaft
Fluid Damper
SFI flexplate
BME aluminum rods
JE 14.5:1 pistons
Clevite coated main and rod bearings
Total seal gapless rings
ARP main studs
Indy 440-1 fully ported heads, extensive work
ARP head studs
720 lift COMP roller cam
COMP roller lifters
INDY single plnae high rise fully ported intake
Harland Sharp 1.7 full roller rockers
HD thick rocker shafts
CM pushrods
middleroadBOB
is this the same motor that you had in gladwin this year?
if so, i can put a video of it up for.
moparhorse
Yeah it sure is. Just dont have any use for it. That would be awsome if you could do that
middleroadBOB
moparhorse
Yeah might want to take that one off there lol. Ran like hell. The ignition ground was loose. Ran awsome the day before doing the sand drag though, real good
middleroadBOB
you can still hear how well it sounds tho. that motor was very impressive
moparhorse
If buyer is serious I will go buy fuel for it and let them ride in it, with a helmet of course, for a very short ride of course, fuel isent cheap.
moparhorse
moparhorse
moparhorse
moparhorse
moparhorse
moparhorse
